My car is an 84 LeBaron with the 2.2 Turbo.
This is an embarrassing question, but here goes: Where exactly is the ground on the "driver's rear corner of the block?" I see lots of references to it, but cannot find it. On the driver's side, there is a ground on the fender well, there is a ground on a bracket at the end of the valve cover, and there is a ground (maybe) to the neutral safety switch. I have the DSMs and look at the diagrams and schematics and all that, but it never says EXACTLY where this ground is, and I can't find it.
Is it something that can only be seen from underneath the car? Or maybe I'm missing that ground wire altogether. Which would certainly explain a lot...
Thanks.
David
Thanks.
David
