I don't think it would fit properly. You will need the bracket which bolts to the block and the jack shaft along with the bearing at the outboard end. When mine finally fails I'll be replacing it with unequal length shafts.
Is there no significant advantage to the equal length shafts? I want the option to do a high-power build later on.Bob ONeill said:I don't think it would fit properly. You will need the bracket which bolts to the block and the jack shaft along with the bearing at the outboard end. When mine finally fails I'll be replacing it with unequal length shafts.
Thats the thing, since torque steer is the main issue with the unequal shafts, the only reason it is really superior to the equal length is because of the lack of availibility of the bearing.ChargedDust said:The intermediate shafts are fairly easy to find used and the bracket, it's the bearing that can't be had anymore. FWD does sell a replacement bearing with a solid aluminum mount for under $100, its made by one of the board members and sold through FWD. Sometimes you can find used axle assys with a good bearing, but most of the time the bearing is shot. They were designed as a sealed unit and can't be serviced in a practical way, so after 20+ years of running and never having fresh grease they tend to be beat up in some way or another.
IMO, anyone talking up the superiority of unequal length is doing so because there was no way to replace that bearing (until recently), so they're blowing smoke up their own butt to make themselves feel better about the lack of an alternative.
That's OK with me, this car is on the road now but still a work in progress. Torque steer on it is absolutely terrible right now, but I still need to do some front end work. Equal length shafts are still under consideration. I will likely raise the boost and get a ported head/exhaust once the rest of the car is in shape, so I'm working on it with that in mind.ssheen said:I went from the equal length set up to the unequal length in my 88 Daytona Shelby. The intermediate shaft couldn't be separated. Can't say I really noticed much difference. I run an LSD too, which is suppose to increase torque steer. Oops, didn't notice the date of the post. My bad pulling up an old thread.
blake_mcguire said:That's OK with me, this car is on the road now but still a work in progress. Torque steer on it is absolutely terrible right now, but I still need to do some front end work. Equal length shafts are still under consideration. I will likely raise the boost and get a ported head/exhaust once the rest of the car is in shape, so I'm working on it with that in mind.
