Did you replace them with generic ones? Often those beams aren't focused.
Who did you buy them from? (What brand?) They usually look very similar but the optics are usually not the same.The ones I replaced look exactly like the old ones. I can't remember the make of them though.
DTMOTO from Ebay. Item number 382163953436Who did you buy them from? (What brand?) They usually look very similar but the optics are usually not the same.
This was replaced approx. 3 years ago (almost to the date). Amazing what a new windshield does for visibility!!Clean the windshield glass inside & outside also. It helps to reduce glare. A new windshield glass without the scratching & pitting of age is a real treat.
But the brighter (and whiter/bluer) the shorter the bulb life since it is done by running the filament hotter. And they cost more.phillips or osram. they have several steps of brightness
Yup... it won't have anything like the OEM focusing ability. Clear, yes, but the optics will be rubbish.DTMOTO from Ebay. Item number 382163953436
Sylvania Silverstar Ultra is exactly the brand that does burn out early. As I said, both sides failed within 5 months, whereas regular bulbs lasted 7 years. I will never use them again.Osram (Sylvania) Silverstar Ultra for the nice white light and a 'Perceived" brightness increase. This is done by the colour of the light output being more visible to the eye. They also have a zXe bulb which I'm running now going on two years, quite a bit whiter still and a bit brighter as well. Do not go with the "high wattage" lamps, they will burn out quickly and the halogen capsule headlamp assemblies don't quite work right with the LED conversions. The HID headlamp assemblies maybe perform better with the LED lamps but I can't comment on that with any credibility.
I must be lucky, my Avenger had them for years...still worked after the front end wreck, I actually took them out and still have them on the shelf here, The zXe lamps I have in now are also Silverstar, just a whiter and cleaner light... 2 years and counting!!Sylvania Silverstar Ultra is exactly the brand that does burn out early. As I said, both sides failed within 5 months, whereas regular bulbs lasted 7 years. I will never use them again.
So the lenses I bought won't focus like OEMYup... it won't have anything like the OEM focusing ability. Clear, yes, but the optics will be rubbish.
P.S. Are there any OEM ones available from another dealer? I know the best bet is from Dodge but I'm looking at price here tooSo the lenses I bought won't focus like OEM. Would the Osram bulbs help any with brightness shining any further down the road or do I need to replace the lenses with OEM ones.
