This is a continance of my earlier post on my timing belt breaking and later, driveability issues on the Daytona, with 2.5L.
Checked vac lines again this a.m. and found one of the egr solenoid lines not hooked up, so I did so. checked plugs, and they were not fouled.
Took it for a full road test, and it ran great for a couple of miles at highway speed, then at a stop, the idle roughened and progressed to rough running at road speed. Made it home, with the idle sounding as if it had a Hi Performance camshaft in it. Sitting at idle, white smoke appeared out of the tailpipe, and smoke in general was coming out of the throttle body. Oil pressure dropped also. Tried one restart, and very rough idle with no oil pressure. Shut if off immediately at that point. I do see evidence of oil leaking from head gasket.
No water in the oil, fwiw and no oil in coolant.
I do have a Mopar Perf headgasket stocked away in the shop...should I go ahead and change it, or might the engine be toast?
