Unfortunately, my worst fears have come true. Been smelling a faint antifreeze smell inside my Daytona at times. The other day I turned the heat on and took a look to find it is indeed dripping a bit into the carpet, just behind the radio / heater controls stack.
I've read some horrid things about the job. I do have fully functioning air conditioning in the car. My biggest question is if there is ANY way at all to remove the heater core without opening up the A/C system. I honestly wouldn't be opposed cutting open and then re-sealing the heater box if I could get the core out that way. It's against my better judgement to do that, but I really REALLY want to avoid opening the A/C system, especially when it has been serving me so well.
Any thoughts? Also, any thoughts on it making through another winter before I need to do the replacement? Like I said, it is dripping at this time, but only appears to do so when the heat is on. At other times, I only smell antifreeze from the vents occasionally.
Thanks,
-Steve
Thanks,
-Steve
