I'll check out that sealant and see if that solves it,because I know that's not good if it has to keep running to level it out that frequently. It's not constant but every minute or sometimes 5 minutes. It just depends. I don't want it to leak so much til it stops working, so I'll be trying lots of ways to make it air tight while it works, starting with that sealant you mentioned. Maybe the easy way will fix it,lol. Don't want the pain of tearing it all back apart. It took me 5 times of putting them on and taking them off,along with the back and forth trips to the yard, to find a decent set used because you can't test them without installing them and that was a pain. Thanks for the idea of the sealant.
