1 - 2 of 2 Posts
Hi,
I have a 92' 360 in a 15 pass. Ram 350- 1 ton- van. I want to convert the motor to a mild build, naturally aspirated MSD electronic ignition/electric choke set up. The current set-up is a PCM system w/MPI as I understand it. I understand this is a Roller set up, so with a headers, a good intake and the right carburator and by passing the PCM I could have a reliable no mess system. This Van will be a camper which I don't want over the road sensor or computer problems showing up. Any help is greatly appreciated.
Thanks,
Oisin.
KOG
Moving to a carburetor is a step backward. You'll probably lose more in driveability and mileage than you'll gain in power. You can get more power from the injected engine with headers and a cam..
1 - 2 of 2 Posts
