Here is the scoop on the car. If you look closely at the fender tag, and understand that stampings on fender tags are notoriously bad (R's look like P's so on and so forth) here is what it decodes as.
RS23=Plymouth belvedere Special GTx 2 door hardtop
L9e= 440 375 h.p 1 4 bbl carb 8cyl 1969 Los Angels Ca
131943= Sequence number
E86 440 High Performance
D32 Heavy Duty Automatic
Y2 Yellow exterior
Y2 Yellow monotone top
P6x Bucket seats black
X9 Black door frames
108 Build date January 8th 1969
319122 Order number
A04 Basic group (AM Radio)
B51 Power brakes
C16 Center console with woodgrain
C55 Bucket seats
G33 Left side remote mirror
J25 3 speed wipers
M21 Roof rail drip molding
M33 Body side molding (rocker panel molding)
R11 AM 2 watt Music Master Radio
V1x Accent stripes (black hood stripes)
V21 Performance hood treatment (hood stripes)
V6x Longitudinal stripes (Black)
So what you have if the order number matches the VIn on the body is a real 1969 GTX. The fender tag is typical for a GTX. Remember the GTX is the upgreade Belvedere with performance, so you get a lot of extras because it is a GTX. One thing that stands out a little is the car was built at the Los Angeles plant. Not to many cars came out of that plant. I would suspect that it was a Non undercoated car since there was nothing on the fender tag about a hood pad or undercoating (they go hand in hand) The car was built on January 8 1969 which makes it a mid year car, and mid year cars can get goofy extras that are meant for the following model year. I have seen this many times especially when it comes to paint colors.
In some of the pictures the color looks very bright yellow, in other pictures the color looks like a soft yellow. In 1969 the Yellow listed was Sunfire Yellow which is soft, almost creamy. Your Y2 color code on the fender tag comes back as Sunfire Yellow which is correct for 69. Starting in 1970 they came out with Curious yellow, or Top bananna yellow which is bright high impact. I have seen some 1969 cars that came out as Plumb crazy which was not available until 1970, so some things do happen.
The fender tag looks like it might be an original. If you look at the top right hand side of the tag you will see a couple of lightly embosed marks. Reproduction fender tags never have that kind of stuff. As long as the VIN numbers match the engine, transmission and if the rear end has the correct production date you can say it is definately a 1969 GTX. Some rear ends got the VIN some did not, so it is a build date on the rear end that lets you know if it was on the car or repalced at a later date.
So the question is value. I would say that the car is nice, the car is straight, the paint is very good. I would say that the interior leaves a lot to be considered. Seats look like they have been used frequently, carpet is old and dirty, dash looks to be a little tired. For 40K you should be getting a nearly perfect car. 40K is a heck of a lot of money to spend on a toy, and it should be right. There was nothing on the fender tag regarding tires or wheels. That is a bit suprising, and curious, but not unheard of.
In the engine bay there are a lot of issues. The car is a three speed wiper car and it has the correct three speed wiper, so thats a good thing. The air cleaner is just plain silly. That air cleaner is from a 1966 C body car. You can tell by the round tube for the fresh air intake. In 1967 the High Perfformance air cleaners got a dual snorkle and the tubes were oval. It's a cheapo air cleaner that they grabbed because they didn't want to pop 300.00 for the correct oval one the car should have. The brake master cylinder looks to be the correct style (they used a couple of different ones depending on which vendor was available at the time) The booster is probably as Cardone that was bought when the original one crapped out. The power steering pump is the correct Saginaw style.
The radiator is not original. It looks like a Modine replacement, or possible a Blackstone. The style is wrong there are no numbers where they should be. Chrysler used two radiator suppliers back then. The main supplier was Fedders and up to 1970 Fedders used mostly round top tanks (some square tops were used but it was rare) the second supplier was Blackstone and they used mostly square top tanks. So you could have either style depending on which vendor supplied which plant so on and so forth. But the numbers should always be in the same place and I can't see them. That top tank on that radiator isn't even close to being right. The fan shroud looks to be wrong. It is too deep at the top. The distributor is wrong. The car should have a cast iron Dual point distributor.
If you look closely at the engine bay you will see where they did a scuff and shoot in the engine bay. The battery tray is nasty, but just behind it on the shock tower you will see the old yellow paint, and under the hood hinges. That tells me the masked the engine bay off and squirted it without taking the engine out. All of the hoses have screw type water hose clamps, they should be Corbin spring clamps. The PCV is on the wrong side of the car. It should come from the passenger side of the engine. The spark plug wires have no factory holders, and probably are generic plug wires. The heater and radiator hoses are probably generic and not Mopar. The heater hose fender clamp looks like it was painted yellow (probably not masked off during painting). The battry is wrong. I would bet that the alternator is not the original.
The wipers are wrong. They are black plastic ones, when they should be steel/aluminum. The front side marker lights are wrong. They have a balck boarder and should be body color. No doubt they are replacements which come in black and they never bothered to paint them. Wrong exhaust tips. They should be ovals and they are straight cuts. The steering wheel has a wrap on it. No doubt it is cracked in a few places. You don't really see the underside, so it's hard to tell what is going on.
The car has a rake to it. Either they turned the torsion bars down in the front or they have extended spring shackles. The car should sit nearly level. It doesn't really mean anything other than it has been fooled with.
All in all it is a nice looking car, but no where near a 40K car. A car like that in this country is maybe a 30K or possibly slightly more if it is numbers matching. It all depends on personal taste and value. There is no value in this car at this price. If it is a question of falling in love with your dream car, then that is a whole different story. American muscle cars are rare in Europe, but that doesn't mean they should be over priced.
