Hi everyone,
One of the transmission cooler line is leaking, in particular, the one that goes on the top of the radiator. I plan to replace both cooler lines, so here are my questions:
1) Anyone used the following parts? If so, what is your feedback? Dorman 624-366 Right Inlet Transmission Line and Dorman 624-367 Left Outlet Transmission Line. Please see: http://www.dormanproducts.com/catalog/OESolutions2006/485-509TransmissionLines.pdf.
Do I need to trim these hoses, or is it exact fit? I'm open to suggestions
2) How difficult is it to remove the cooler lines and to attach the new ones, especially the end that connects to the transmission? Is there any special tool that I need to use, other than a screwdriver? Do I need to remove other parts to get to the transmission connection? Looking from the top, i cannot see how the hoses connect to the transmission. The hoses are attached to the transmission using hose clamps with a screw tightener.
3) Can i please get detailed instructions on how to do this repair?
Thanks in advance.
Thanks in advance.
