Since I bought the vehicle, there has been a clunk on the right side. Upon inspection, I quickly found that the right side sway bar end link was bad. The left side has been replaced recently, so I replaced the right side. The clunking is gone, awesome! After about 200 miles, there is a god awful metal on metal sqeaking coming from it while driving, and it can be heard clearly coming from the lower suspension if you sit on the right side fender and bounce the car's suspension down. I did grease the end links, and also greased the grease fitting on the upper control arm. Did I install it wrong? It seemed pretty straightforward installing it... Thanks.
