1 - 4 of 4 Posts
hello,
I recently changed the valve pan gaskets and not sure I hooked the breather hoses back up right. one connects the two together and the other one goes to the air filter plastic piece. I was told that this is important for pressure and can cause leaks is this true, and also which goes to breather and which connects the two pans.....
What car and what engine? The breather hose goes from the valve cover to the air cleaner, and the PCV hose goes from the other valve cover (if it's a V-6 or V-8) to the throttle body or caburetor.
I haven't seen one up close, but what I posted should be relevant.
1 - 4 of 4 Posts
