G
greg.owen
·Guest
I have a 96 Voyager with 3.0 V6 and R134a refridgerant in my AC system. Every 6 months or the so I have to get the AC filled and each time its pressure tested as OK.
It was suggested that the evaporator may need to be replaced and would cost about a grand to do it as the dash needs to come out.
Here in sunny florida, the system needs to work. At present it blows cold in the mornings and when kept in the shade but if left in full sun it takes ages to have any effect so I figure its time to top it up again.
Is it easy for a novice to add coolant? If so could someone please let me know how? Is there any way I can measure the amount of stuff required. I am also interested in whether I can add the dye that would enable me to trace any leak.
You guys have always helped me before, so I know I can trust you to do the same this time. Thanks
