I have been having problems with my transmission in the last couple of weeks. I changed out the fluid and the transmission filter. Codes thrown indicated
voltage out of range for the input speed sensor, which was replaced yesterday. ANother code indicates a gear ratio out of range for fourth gear and I believe another code or may be the same code related to the compounder. I took vehicle to the dealer yesterday after having the input speed sensor replaced. It worked perfectly for about 5 minutes and then started to do the same thing as before. When you started off in I guess first gear, it will not auto shift into second or any other gear. I engage the the manual shift and I am able to shift through 1 through 6. Sometimes this doesn't work though and If I stop, turn off vehicle and restart, it I can again manual shift. How long can I drive this way. My caravan is a taxi and it goes off stand December 1 and I will have to sell it.
2009 Dodge Grand Caravan
3.8L 6 cylinder SXT with 62Te Automatic Transmission.
Thank you for any advice.
