The FSM said the window regulators would be attached to the inner door panel with screws and nuts, but they were pop-riveted instead. So I've got the pop rivets drilled out, and the regulator is free, but there is not enough clearance between the regulator and the division channel to get the regulator out; in fact, I can't even move the regulator arms enough to free them from their slots in the glass bottom channel or the inner door. The FSM is very sketchy on removing the regulator. I think you need to loosen and move the division channel in order to get the regulator out, but I'm not sure. I've removed the lower division channel bolt which is accessible through the hole near the right lower corner of the door panel, but there is obviously another bolt somewhere else, higher up, holding the division channel in place, and I can't figure out what or where that bolt is.
How do you remove the division channel? Any suggestions would be greatly appreciated.
