HOWTO: Install a digital dash in an analog cluster AC/AY
9742 Views 7 Replies 3 Participants Last post by  Oklahoma Wolf
Note: I'm using my '92 as the example for this, but the big thing is to use a dash that matches the year of your car.
Step one is to get the wiring diagrams. The one for my car is here: http://oskin.ru/pub/chrysler-dodge/manuals/Service Manuals/1992_AX_Acclaim_Dynasty_LeBaron_Shadow_FifthAvenue/92FWD_8W.PDF
Yours may be different.
Step two: Get wire. Lots of wire. (Not really lots, but it will make life easier when extending wires from the right to left side of the cluster.)
Step three: Get the digital cluster AND BCM from your donor car. The mileage will be incorrect, but if you don't grab the BCM, you'll find that your water temp, oil pressure and possibly fuel level will all be incorrect. Not only this, but on a Dynasty with the single-connection BCM, you will have the most godawful, irritating constant tone from key-on until you pull the battery. Get the donor BCM. I learned this the hard way. Also, don't forget the little lightbulb on the pigtail to light up the PRNDL indicator. It's a good idea to go ahead and change all the bulbs while you're at it. I used green dimmable 194 LEDs from a local supplier, here in Missouri. You can test by connecting pin #7 to ground, and pins 2 and 11 to 12V. Remove the brake warning bulb, because it'll be constantly on, with a non-ABS car and an ABS cluster.
Step 4: It's a good idea to disconnect the battery, here. I recommend doing this in a well-lit garage, and have a lamp with a flexible head to point at your cluster area.
Step 5: Yank the cluster out of your car. I'm not going into this process in-depth, because it's pretty self-evident. Just pull the five screws along the top, pull the trim piece off and then the four screws to hold the cluster in. Should go just like your junkyard pulling did, but with slightly more care.
Step 6: Once you're clear, you should have two plugs there. Go ahead and cut these off.
Step 7: Let's get the hard part out of the way, now. Namely, the adding wires where they didn't properly exist, before. From the "L" shaped plug, you want to run the grey-yellow across the car to pin #11 on the red plug of your donor BCM, and the violet-yellow wire from the round plug, to pin #24. This will get you your oil pressure and your temperature sender feed. Then, go ahead and plug the BCM in.
Step 8: If you haven't done so already, go ahead and pull the panel covering the radio bolts, and unbolt the radio, sliding it forward until you can see the connectors. Tap into the pink/light blue wire, and extend it into the instrument panel cavity. This will get you the "courtesy light" feed that you need. Another lesson I learned the hard way.
Step 9: Play contortionist for a few minutes, get upside down under the dash and tap into the violet/brown and the white/black wires on the diagnostic connector. Make sure to run them, in twisted pair, up through the dash and have them pop out inside the cavity.
Step 10: At this point, you can simply match the colors. You DID make sure and get plenty of pigtail, right? For the wires you extended, make sure you marked them with the original colors, if you didn't use the same color wire as the original. You can also add in the little 194 on a lead now, again matching colors. Heat shrink over all soldered connections.
Step 11: Reconnect the battery and turn the key on. With luck, it should all light up. Make sure all your readings are decent, then start the car. Test the functions, and if it all works, just button it back together and take it for a test drive.
Here's mine, after I put in the cluster. (Note: Mine is currently using the original Dynasty BCM, because I don't have a digital cluster Fifth Avenue/Imperial one. Because of this, I had to pull the BCM apart and cut the wires to the piezoelectric chime to get any sanity while driving. Don't do what I did, get the donor car's BCM.)
Reactions: 2
1 - 8 of 8 Posts
Nice write-up. By getting the premium BCM, I believe that it will also support all the functions of the overhead trip information computer (OTIS) as opposed to just the compass/temperature readout.
Not only that, but you won't get the incessant tone coming from the chime, either. It's worth getting the premium BCM for that, alone.
It's also worth mentioning that even though you can remove the shift indicators on both clusters, they don't interchange with each other. The analog one does not fit the digital cluster housing.
That stands in direct contradiction to my experience. Mine fit perfectly in both the 92 Fifth Avenue cluster and the 88 New Yorker one I have.
Hmm... when I swapped my '91 Fifth from analog to the LeBaron GTC digital cluster, the shift indicator did not swap over. Might be a '91 only analog cluster thing, as the '87 GTC digital cluster uses the same housing as all AC/AY digital clusters.
The AA body cluster is different from the AC/AY, even if it will fit into the dash. Namely, the shift indicator is the big housing difference.
It's the same housing right down to the shift indicator illumination hole, the shift indicator is just blocked off in front and must be modded to allow it to be seen. Here's mine, installed in the 1991 Fifth using the shift indicator from one of my 1992 digital clusters. The shift indicator from the '91 Fifth's analog cluster didn't fit, but it's been a while so I'm not sure in what way.
Otherwise, installing this one in an AC/AY is fairly easy... just some extra wiring. You need to run a tach wire to pin 43 of the ECM, or this cluster reads no oil pressure. It's also missing certain warning lights.
I was going to put this in the Imperial, but never got around to it. It hasn't been needed.
1 - 8 of 8 Posts
