I need help finding an axle seal for my Valiant
1090 Views 3 Replies 2 Participants Last post by  Chris65
Hello to anyone who can help me with my dilema. I find myself in desperate search for an axle seal for my 76. Im not 100% sure its the original never replaced but what i do know is its the 71/4 gears with 4" bolt pattern on 9" drums. I have tried a couple of seals from a couple of locations but none have been proper, the one that was in the axle had the numbers 3432691 and 4-432. If someone knows where I can get this part or a number that matches that would be very helpful. Even if someone has old stock they are willing to part with one of those I would be grateful as this is my winter car and thats coming up fast.
1 - 4 of 4 Posts
· Registered
The National brand part number for your seal should be 5124.
Here are the dimensions:
Shaft Size: 1.326 in. (33.68 mm.)
Housing Bore: 2.226 in. (56.54 mm.)
Outside Diameter: 2.247 in. (57.07 mm.)
Width: 0.5 in. (12.7 mm.)
Material: Nitrile
O'Reilly Auto carries these seals, and I am sure other part stores can cross the National number to their brand. There are also NOS seals on eBay
· Registered
Ooops, didn't realize you are in Canada. You may want to try a parts store still. Isn't there a big chain called Canadian Tire there? I don't know if they sell repair parts, but National and Timken are available worldwide, so you might want to give it a shot. Otherwise, glad to help.
1 - 4 of 4 Posts
