I have a 2.5L Caravan. It has run without trouble for years. Just recently, it has started to sputter a bit while idling and kinda 'hunts' for a stable idle position. Then it suddenly dies. It will re=start, but this pattern starts all over again. This has been a gradual buildup over perhaps a month.
Before I start changing things, anyone had any similar situations? What did you do to correct the problem? The air cleaner is clean, there is plenty of fuel. I am thinking it might be the fuel filter. I have not changed it out since I have owned the van. It has 197K on the engine.
Thoughts, suggestions and knowledge from those of you who have experienced the problem much appreciated.
slim slow slider
