Where are you located Jeremy? I too have a black and gold Turbo Z C/S.
1969.If you still own a Daytona what year(s) do you own.
If you own more than one of the same year post it here and I will edit the poll to reflect that.
1969.
I know... I felt left out!This was G-bodies - but the earlier ones were nice, too.
I had the inserts for the defroster out, and see 4-13mm bolts that hold the dash to the firewall. I did not remove them mostly because it looked like I should remove the center stack to pull back the dash and probably other things. Even looking up from underneath and removing the lower side panels to the console, dropping glove box, pulling the heater controller and radio out I could not see the module-I've looked online and cannot find any description for actually removing the module, but plenty on how to repair it once out.The control module is in the center stack, near the radio. They suffer from bad solder joints as well as the epoxy filling leaking out like goo all over everything.
