Imperial History and Production Numbers, 1955-1983
by Gerard Wilson
This is the fourth article in a series. For details on production records and how these numbers were calculated, see the first article in this series, "Plymouth U.S. Production Figures 1946-2001."
To build these tables, I examined all of the sources of information on each make and model, and tried to determine the most accurate figure for that make and model.
These tables are not definitive or fully accurate. They are the best I could do with the information which I was able to uncover. I would welcome correspondence with anyone who is interested in this material and can correct any errors or misinformation on my part.
- Gerard Wilson, May 2013
United States Imperial production
1955-1963 Imperials
The Chrysler Imperial had always been the most most luxurious Chrysler offering, but in 1955 Chrysler made the Imperial a separate make, with no Chrysler label, to compete with Cadillac.
Land vehicle Vehicle Car Classic car Full-size car
Imperials were often superior to (and more expensive than) Cadillac and Lincoln, but never sold well, and the Imperial reverted to being a Chrysler model in 1971.
The first standalone Imperial was the 1955 model; the body and chassis were different from those used by Chrysler. It was built on a 3.3 meter wheelbase. There was only one trim line, but that line was lavish and completely equipped.
A Crown Imperial limousine was built for 1955-1956 on a 3.8 meter wheelbase, with hand assembly and finishing. This would be the last of that traditional body style built in the U.S.
Chrysler may have considered the 1955 model too small, so an extended 3.38 meter wheelbase chassis was built for 1956.
Land vehicle Vehicle Car Full-size car Classic car
Imperials for 1957-1959 were "the finest expressions of the forward look," Virgil Exner's dramatic styling which was undermined by poor assembly quality during the introductory year. Subsequent models were improved, but sales never matched those of the flawed 1957 models. Nonetheless, this model cycle was the most successful Imperial; the 1957s recorded more than double the sales of any other year Imperial was sold until 1964.
During this period, Imperial continued (like its competitors) to be built with a body-on-frame structure, while all other Chrysler products switched to unit-body for the 1960 model year. Under Virgil Exner's direction, design was dramatic, but the cars had limited appeal against the more conservative Cadillacs and Lincolns. Concerns about quality lingered among upscale buyers, even though Imperial quality was equal or superior to Cadillcs and Lincolns.
195519561957195819591960196119621963total
Imperial11,25911,259
Crown172226398
Imperial10,45810,458
Imperial, Crown, LeBaron 37,55716,102
Custom, Crown, LeBaron 17,26270,921
Custom, Crown, LeBaron 17,70312,24914,33714,10858,397
11,43110,68437,55716,10217,26217,70312,24914,33714,108
1964-1970
196419651966total
Crown, LeBaron 23,28518,39913,74255,426
Lynn Townsend took over from L.L. Colbert as Chrysler President in 1961, and replaced Virgil Exner with Elwood Engle as head of design. Engle had come from Ford, and the 1964-1966 cars were elegant, reflecting his past work, especially the acclaimed 1961-1963 Lincoln Continental. Imperial volume did not improve, and although the company was doing well enough to carry Imperial, the low volume was drawing attention. (Probably because of that very same low volume, Imperial remained body-on-frame through 1966.)
The short-cycle 1967-1968 Imperials finally used unit body construction, an arrangement which (once again) allowed component sharing between Chrysler and Imperial to reduce costs. Chrysler sales at this time were strong, and the attractive Chrysler probably drew some buyers from the Imperial.
Chrysler introduced a sleek "fuselage" design theme for all of its large cars in 1969, and the Imperial received the largest, most elaborate, and most carefully assembled version.
1967196819691970total
Imperial, Crown, LeBaron17,614
Crown, LeBaron15,36132,975
Crown, LeBaron22,07711,81633,893
Although Imperial was larger than the top Chryslers, they shared the same passenger compartment. The Imperial in this form remained in production through 1973, and was an elegant car, meeting new federal safety standards more artfully than most.
They were lavish, quiet luxury cars, and the torsion bar suspension gave them them a drivability advantage even with their huge mass.
However, when volume for 1970 fell to the level of 1955, it was the end of Imperial as a separate make.
Between 1971 and 1973, the car became the Chrysler Imperial. It was also built as such for the first two years of the 1974-1977 cycle, now sharing the same structure with the New Yorker. The name was then dropped (the basic package remained as New Yorker Brougham), although it would reappear on the 1981-1983 Canadian built J body Imperial and 1990-1993 Chrysler C body New Yorker and Imperial.
Canadian production
Land vehicle Vehicle Car Full-size car Motor vehicle
Chrysler took the second generation J body coupe platform (Dodge Mirada/Chrysler Cordoba) and developed it into a full luxury coupe, to compete with the Cadillac Eldorado and Lincoln Continental coupes. It was a beautiful design, except perhaps for an awkward rear deck profile. Every effort was made to ensure assembly quality and to separate the car from its J - body origins.
The Imperial had an exclusive fuel-injected version of the 5.2 liter V8, but this unit proved to be unreliable, generating warranty work and keeping buyers away. Model year production is compiled from monthly totals and changeover dates.
198119821983Total
Imperial "J" Coupe7,8872,9431,55512,385
Editorial note. Wheelbases are in meters because the author is Canadian. A meter is around 39.4 inches.
Sources
  1. Chrysler Canada Ltd. Model chart and serial number guide, internal document, 1957 (?)
  2. Chrysler Corp. Model chart and serial number guide, internal document, 1958 (?)
  3. Auto Editors of Consumer Guide. Encyclopedia of American Cars. Publications International, 2006.
  4. Grace Brigham. The Serial Number Book for U.S. Cars 1900-1975
    Motorbooks International, 1979.
  5. Don Butler. Plymouth-DeSoto Story. Crestline/Motorbooks International, 1978.
  6. Jerry Heasley. The production figure book for U.S. cars
    . Motorbook International, 1977.
  7. George Dammann. 70 years of Chrysler. Crestline/Motor Books International, 1977.
  8. John T. Lenzke. Standard Catalog of Chrysler, 1914-2000. Kraus Publications, 2000.
  9. Richard Langworth. Chrysler & Imperial, the postwar years: 1946 - 1975. Motor Books International, 1976
  10. Walter P. Chrysler Club. Walter P. Chrysler Club News. Various issues.
  11. Ward's Automotive Yearbook and Ward's Canadian Automotive Yearbook
  12. Articles on Imperial automobiles which appear on this site were used in the preparation of this table. Another excellent source of information on Imperials is the Imperial Club, and Aaron Severson's automotive history site, which has many articles on Chrysler and Imperial.
Also see:
Also by Gerard Wilson: Chrysler 1945-48Chrysler 1949-52Chrysler 1953-54Chrysler 1955-56
and Production numbers and histories, 1946-onwards
