98 Grand Voyager LE AWD with the infinity system .
I bought this for next winter it will strictly be a work van so as such i have no interest in hauling it all apart to replace speakers and rewire everything . The system in it sounds decent problem is no MP3 cabability obviously.
So i installed a JVC kd-g700 19RMS 50Peak watts stereo with the proper adapter and hooked up the blue wire to turn on the amps and after about 24 on the volume the amps start clipping at least what i assume is clipping the speakers will cut out randomly turn it down a bit all is well thought maybe the HU was bad it is an older HU that had given me grief before not like this though.
Tried the HU from my 02 caravan jvc kd-g230 20RMS 50Peak watts same thing ! tried turning the bass off that helped a bit but it still clips pretty bad at anything past half volume.
At this point im thinking the aftermarket HU's are putting too much voltage to the amps ? Thing is i have read about many people doing the same thing with no problems so any ideas what the cause could be ? As a side note i can crank up the factory HU as high as she will go with no clipping and very little distortion almost unnoticeable and the factory one will go a lot louder that the aftermarket ones will before they start clipping.
I am not against the idea of putting in another factory HU if i can get one that can handle MP3's without clipping or one that has an AUX jack to plug an MP3 player into if i have to rewire the HU wires that's fine i just dont want to start tearing panels off and upgrading speakers and rewiring everything .
I am open to any suggestionsto make this work short of tearing the van apart the cheaper the better
