This is using a 1991 SBEC with a modified calibration. I just finally got the SBED to work correctly as far as "waking up" on input from the distributor HEPs. I went ahead an put some ethanol free premium gas in the tank, ran a jumper from the bulkhead connector to the left side body harness to run the fuel pump.
Using a spare turbo distributor, with the key on, got fuel pump activation, and immediately found a bad O-ring on the pressure regulator. Fixed that, and tried again. The fuel rail and injectors are not installed in the intake as I am using the 1987 2 piece intake. This time I did get a beautiful cone shaped pattern from all 4 injectors, but rather than triggering sequentially as the SBEC is supposed to, they were either bank firing, or all at once. They seemed to be firing as a batch fire, all 4 at the same time.
My question is, does the SBEC have a basic "fail safe" limp mode if the sync HEP is bad and fire all 4 injectors simultaneously as part of that strategy. The reason I am asking, is I know Ford did on their DIS V6 engines so it wouldn't leave you stranded if the cam sensor failed, they would revert to a bank fired mode.
I do not have the dash installed, so do not have the MIL available for the "key dance". After this current batch of nasty, very cold weather I can repeat everything with my Snap-On Solus Pro and see if it shows any HEP related codes. I know I will get an O2, air temp and knock sensor codes since with the upper plenum off and the fuel rail off the lower, those are not connected.
