Jeep's 4.0 liter PowerTech Straight-Six Engine
From material by Peter Stern;
with thanks to Frank Swygert
The Jeep 4.0 liter six-cylinder engine provided good acceleration from low speeds in Jeep Wranglers and Cherokees for years, with high torque at low engine speeds. It was used in other vehicles (such as the Grand Cherokee) as well, a strong, durable performer loved by its owners.
Based on the old 199 cubic inch Typhoon Six (launched in 1964 via the tall-deck 232), the AMC 4.0 liter engine used a shallow-skirt cast-iron block with evenly spaced cylinder bores, loop-flow combustion chambers, in-line valves, and a seven-main-bearing crankshaft.
AMC historian Frank Swygert reported that the 4.0 block is around 1/8" wider than its predecessors, with the 0.10" larger bore offset by taking away support for a mechanical fuel pump. The heads can be bolted to the earlier 232 and 258 blocks (the ports on the right edge have to be sealed when this is done).https://www.allpar.com/
Engineers preserved parts and dimensions to cut tooling and inventory costs, so most internal parts interchange, according to Swygert, among the late-1964 and newer sixes in the 232/258/4.0 family. He wrote that it's "relatively common to put a 258 crank and rods in a 4.0L to make a 280 inch six. This can be done with all stock parts (258 crank/rods, 4.0L block/pistons), but most often a special piston is used along with the slightly longer 4.0L rods."
In 1986, AMC was using a troublesome 2.8 liter V6 from General Motors and their own 258 (4.2 liter) straight-six, which had been derived from the 232. The 4.2 was used in the CJ7, Concord, Spirit, and Eagle, after debuting as the sole Eagle engine and a Wrangler option.
The related 2.5 liter four-cylinder, which appeared in 1983, was based on the same architecture; Frank Swygert wrote that it was essentially the 258 with the center two cylinders removed and a new head. The four-cylinder produced 125 horsepower in its final years, and, causing some confusion, both replaced a 2.5 liter GM engine and co-existed with a Chrysler 2.5.
Mopar sold a 4.7-liter I-6 stroker long block, to deliver around 265 hp and 290 lb.-ft of torque, for any 1991-2006 Jeep 4.0.
When the 4.0 burst onto the scene in the 1987 Cherokee and Comanche, it had 173 horsepower (215 pound-feet of torque). By comparison, in 1990 (three years after the 4.0's debut), the GM 4.3L V6 only made 160 hp, the Ford 4.9L I6 only made 145 hp, the Ford 4.0 V6 made 155 hp, and the Nissan 3.0 V6 made 153 hp.
Jeep upped the ante a few times; by 1988, power had crawled up to 177 hp (224 lb-ft), and in 1991, the Cherokee's version was boosted to 190 hp. The engine had a lightweight tuned cast-aluminum intake manifold with long runners for higher torque; the exhaust manifold was tubular steel.
The YJ "Universal Jeep" stuck with the old 258 six (4.2 liter) until the 1991 model year, when it finally gained the 4.0 - but only at 181 hp, possibly due to a more restrictive exhaust. Even so, the 4.0 remained competitive with small V8s and big truck sixes.
The 4.0 used a Renault-Bendix, or Renix, fuel injection system from its 1987 launch until it was replaced by a far more reliable Chrysler system in 1991. This used standard Chrysler engine computers, allowing easier diagnostics: two yellow rubber covers on the right side of the engine compartment let dealers get codes and do certain tests. (Rob Mayercik wrote that the Renix system did not store codes.) The Chrysler system had a different type of cam position sensor, with no knock sensor or EGR.
At the factory level, a new Ingersol engine block line was installed in 1996; a new head machining line was installed later.
Willem Weertman, in his definitive book, wrote that many changes were made between 1996 and 1998 to cut noise, vibration, and harshness from the 4.0 engines, including a new cam lobe profile to cut valve seating velocity, isolated valve cover fasteners, and adding a main bearing brace.
As for why the engine was dropped, according to Bob Sheaves, it...
AMC - Jeep 4.0 liter engine repairs and such
Bob Sheaves wrote:
Karl Stolz wrote that the pressurized coolant surge tank tended to get pinhole leaks, and that there are alternatives which can work better at cooling. Rob Mayercik wrote that Moroso sold an aluminum coolant tank that took a standard radiator cap; he added,
AMC/Jeep 4.0 Six Cylinder Engine Specifications
The 4.0 was also replaced by the 4.7 liter V8, codeveloped with the 3.7, and, in the Wrangler, by the "minivan" 3.8 V6, temporarily, and, later, by the 3.6 liter V6.was due mainly to age of the manufacturing tooling, which was worn out. The long stroke made it harder to clean up the emissions of NOx, and NIH ("Not Invented Here"), in my opinion, also reared its head.
To completely retool would have cost as much (almost) as the 3.7L V6 did, and the Dodges were going to use the 3.7 as a base engine. Logically, the engine group did what they were told to satisfy the dealers...."Make a modern engine, and junk the old ones." This statement is my opinion, based on conversations at the time.
Bob Sheaves wrote:
The 4.0L was a strong performing engine. There were a couple of issues with the basic design, including leaks. In addition, the oil pump was notorious for wearing out at around 145,000 to 155,000 miles, and the TPS (throttle position sensor) on the 1989/1990 models would fail if someone spit on the sidewalk. Make sure you have about 30 lbs oil pressure at idle (+/- 5 lbs).
Stanley Burton wrote:For loping and rough idle, I'd start with a good throttle body cleaning (Mopar combustion chamber cleaner spray works), then progress to a full tune-up. You could also see about having a good injector cleaning done. The original Renix injectors have been known to leak from the seams; if there's any indication of a leak, replace the injectors. I've heard good things about Five-O Motorsports' Jeep injectors. [Bob Sheaves agreed but used 5.8-liter Ford V8 fuel injectors with a standalone Haltech sequential injection system.]
Check the EGR valve if you have a Renix system; later (1991+) 4.0s with the Chrysler electronics use exhaust scavenging instead. I've heard of clogged EGR valves causing a number of problems.
Generally, though, the 4.0 engines were very long-lived, taking positions of honor in the Allpar 200,000 Mile Club.My 1992 Cherokee 4.0 I-6 had constant oil seepage from the
rear of the engine. My dealer replaced the plastic valve cover with a die
cast aluminum one with no success. I finally traced
the oil to the oil filter mount. The O-rings that
seal the oil filter mount are Nitrile (aka Buna-N, NBR) which have limited
life. Replacing the O-rings with the same size but with 70 Durometer
Viton rubber solved the leakage. My fix lasted the life of the vehicle.
Horsepower | Torque | |
1987 | 173 @ 4,500 | 215 @ 3,000 |
1988 | 177 @ 4,500 | 224 @ 2,500 |
1992 | 190 @ 4,750 | 225 @ 4,000* |
2003 | 190 | 235 |
* 190 / 220 on Wrangler |
