K-member swap
1969 Views 4 Replies 4 Participants Last post by  KOG
Does any one know if a 1972 A-body K-member will fit into a 1975 valiant?
Before I start to remove the existing slant 6 member, I would like to make sure that the v-8 member will fit.
Everything looks compatible except the sway bar. The sway bar passes through the slant 6 k- member, but there are no holes in the 1972 v-8 member.
1 - 5 of 5 Posts
· Registered
yes i´tll fit but you would be better of using a 73- up one since these will use the spool type engine mounts.
· KOG
V8 sway bar goes trough the K member. Not a problem, you're going to want a larger one anyway.
1 - 5 of 5 Posts
