Hey All,
Saturday Morning Update:
Went out this morning at 8:30 a.m. to see if Lorrie would start&run.
Checked the Battery = 12.31 Volts.
Checked the continuity of the Fuses. They were fine.
Gave the Accelerator a 2-second push, and a 2-second release.
Turned on the Run Switch, and activated the Start Switch. Lorrie cranked, but didn't start.
Gave her a short shot of Start Fluid, and hit the Start Switch, and she started right up!
Warmed the Engine up, and checked the Transmission Fluid Level. It was right on.
Checked the Charge Rate. It was 14.13 Volts.
Drove to see neighbor Robert, and back.
Got back and shut down, and then checked the Battery, and it was at 14.01 Volts.
Lorrie's Speedometer Cable needs lubrication.
Am also going to have to take the Dash Panel loose and see why there is no Brights and no Indicator Light when the Headlights are on.
Can't figure why Lorrie won't start without Start Fluid. Am going to have to figure that out.
Anyway, at least Lorrie IS starting&running. Will have to see if she will make the trip to and from Livingston, but am not going to do THAT today. Am not feeling too well. Got a bit over-tired the other day putting Ms. American up on the Jack Stands. Need to rest up from that.
Hope everyone is doing well.
JC
JC
