Not sure what happened.
Car ran great yesterday back home from work. This morning I had all the parts I needed to put the speedometer back in, hooked everything up, cleaned up, and press on. But now the car will not even turn over.
The battery has power and all the lights, door looks and windows, rear window defroster, turn signals, 4-way, ac blower fan, everything has power. The only items not working are the radio, accessory key position, key start position, and of course the starter itself is dead silent.
I checked all the fuses in the box and all are good. I switched out the PCM and still nothing. I replaced the started relay last month but even if it had gone bad that would not affect the radio or key accessory position.
Is there a similar relay to the starter I can switch into place to see if that makes a difference?
I took everything apart again thinking I may have connected the two bundle wires onto the instrument cluster on the back side incorrectly but they were fine. One weird thing was I pulled the lights switch out and while the lights came on the temp gauge on the instrument cluster reacted and moved when the light switch was placed on and off.
Any suggestions?
Any suggestions?
