Which floor tunnel should I use with an F-Body Overdrive-4, if I want to swap it into an '82 Dodge Mirada?
Correct me if I'm wrong but; weren't the OD vehicle bellhousings different (larger hole) to accommodate a bigger front tranny bearing/seal 'retainer', the exact name of that piece escapes me at the moment.Yeah the only real external difference is the 3/4 lever is flipped, 4th gear remains 1:1 but becomes 3rd gear due to the reversed lever then the old 3rd gear becomes OD.
