OK thank you!ImperialCrown said:I usually try to use screws holes that may already be there for the inner fender liner/shield. You may have to drill an additional hole or two. Installation screws should be in the package.
Start with one screw to hold the flap and step behind the vehicle to see if they are aligned straight before installing the rest of the screws to secure the flap.
OK perfect, that was my only concern,ImperialCrown said:Inner plastic shield if you can. Plastic won't start rusting.
