I've finally gotten the paperwork done and our 06 on the road. It seems to have been a good buy, but I'm on a steep learning curve.
I swapped the front tires, which are directional, and the noise when stopping is much less. I suspect a better choice in the next set may eliminate the noise.
I did look at the rotors and pads. Pads don't show much wear, but the rotors are fairly worn, but evenly. I'll probably monitor for a while, and replace rotors when the pads need replaced, or if something changes. It stops well, straight, and with no lope, so I'm not keen to fiddle with the system.
BUT - over the weekend my ABS light came on. No hint of trouble. I searched but found only one hit, and it was unrelated. I tried the "key dance," but got nothing I could recognize. If there is a light I didn't find it. Is this car too new for this?
I'd appreciate any input, and will report back if I can get any trouble codes from the O'Reilly's.
Thanks,
Michael
