Hi Smitty, welcome to the forum. First thing to do is verify the float level, it may be set too high. Second thing is fuel pressure itself, ensure it isn't above 4.5-6psi even though I think 7psi is max, no need to go that high with a carb. Third thing is the vents in the carb top, there may be a fuel return line that should be hooked up so expanding gasses have a place to go properly with the carb, and the last thing is make sure when she is warm that the choke isn't resetting itself automatically, they can if out of adjustment, to which flooring makes it open a little bit, above the flooded engine needing a fully open carb to clear when hot. These are all starters for problems with a carb, verify these most common things first.
