Hello, I have a 2005 convertible turbo pt cruiser. I have a clunking noise under the front end. I have had the bearings replace, control arms, shock assembly, sway bar, bushings and inner tie rods. I still have this mystery clunking noise. It only happens when there is a load on the tires. It happens if you go over a bump and if you go up an off set where it articulates. Can someone please give advise?
Thanks
Thanks
