Live highlights from race can be found on
http://hometracks.nascar.com/live_ncats_icar_070713
1:28
Going to be a lot of spots we won''t be able to see - so we'll try to update as best we can; Guessing there will be a ton of action in final turn and Turn 1. Fortunately, those are right in front of us
1:30
Courtemanche and DWhite dropping to rear for unapproved adjustments; coming to green
1:31
Green Flag - and everybody gets through Turn 1 unscathed as Ranger jumps into lead
1:32
Lap 1 - Steckly has gotten past Lapcevich
1:33
Lap 2 - LP Dumoulin putting pressure on Lapcevich for p3
1:33
Lap 2 - Scannell bring it down pit road for a quick stop
1:34
Lap 3 - Ranger has already opened a 1.783 second lead over Steckly, Lapcevich, LP Dumoulin, Fitzpatrick
1:35
Lap 3 - CAUTION - Vaninni - (Ford) is stopped on the course
1:36
Lap 3 - Under yellow, Ranger leads Steckly, Lapcevich, LP Dumoulin, Fitzpatrick, Hathaway, Labbe, Micks, Kennington, Arseneau, RSeibert, Roy, Guenette, JF Dumoulin, Dowler, Beauchamp, BWhite, Courtemanche, Jackson, JWhite, TSeibert, Scannell, Vannini
1:36
Comment From Tim M.
Does the track run full-course or local section cautions?
1:37
Both
1:37
Everybody played nice on the race start. We'll see what happens on the first restart
1:38
Lots of contact marks on the right side of TSeibert's car - (Dodge with MOPAR Engine)
1:45
TSeibert comes down pit road as the field gets the 1 to go
1:47
Ranger and Steckly lead the field to the green for the restart to complete Lap 6
1:48
Everybody gets throught Turn 1 and 2, looked like Fitzpatrick making a move on LP Dumoulin for p4
1:49
Looked like LP Dumoulin slipped up a little attacking Lapcevich and that opened the door for Fitzpatrick
1:49
Lap 7 - Fitzpatrick uses inside move in Turn 1 to take p3 away from Lapcevich
1:50
Lap 7 - Scannell goes around in Turn 2 after contact with DWhite; Local caution as Scannell gets it going and drives off
1:52
Lap 8 - Ranger out to a 1.009 second lead over Steckly, then it's Fitzpatrick, Lapcevich, LP Dumoulin, Labbe, Hathaway, Kennington, Micks, RSeibert
1:53
Lap 9 - Leaders still remain the same, while JF Dumoulin has gotten past RSeibert for p10
1:54
After RSeibert, Guenete is p12, followed by Roy, Arseneau, Dowler, JWhite, Beauchamp, Seibert, BWhite, Coutemanche, DWhite, Scannell and Jackson. Vannini is out, accident
1:55
Lap 10 - Looks like Top 3 have seperated a little from Lapcevich and LP Dumoulin
1:56
Lap 11 - Scott Steckly staying with Andrew Ranger. Lead is just .646, while they've opened a 2-second gap back to J.R Fitzpatrick (Chevrolet)
2:00
Lap 13 - Ranger lead still at .693 over Steckly, then two seconds back to Fitzpatrick, Lapcevich, LP Dumoulin, Labbe, Hathaway, Kennington, Micks and JF Dumoulin
2:01
Lap 14 - Kennington (Dodge) pressuring Jason Hathaway (Dodge) for p7
2:01
T Seibert (Dodge) has come down pit road
2:02
Lap 15 - Halfway: Ranger leads Steckly, Fitzpatrick, Lapcevich and LP Dumoulin
2:03
Lap 15 - They have a sizable lead over Labbe in p6, then Hathaway fending off Kennington, followed by Micks and JF Dumoulin
2:04
Gunette is p11, followed by RSeibert, Roy, Arseneau, Dowler, JWhite, Beauchamp, Scnanell, Courtemanche, BWhite, DWHite. TSeibert, Jackson and Vannini
2:04
Best battle at the moment is for p3, as Lapcevich (MOPAR/Dodge) and LP Dumoulin (Dodge/Spec) are stalking J.R. Fitzpatrick - (Chevrolet)
2:05
Ray Courtemanche Jr. (MOPAR/Dodge) hits pit road just as T Seibert's( (MOPAR/Dodge) day is over because of transmission problems
2:06
Lap 17 - LP Dumoulin just dove under Lapcevich and took away the fourth spot
2:08
Lap 17 - LP Dumoulin (Dodge/Spec) uses short cut in Turns 12-14 to take third from Fitzpatrick -( (Chevrolet) NASCAR officials telling him he needs to give spot back
2:08
Dumoulin has given spot back. No Penality.
Andrew Ranger looks like he has this win in the bag???? 10 laps to go!
2:10
Lap 19 - Ranger has stretched his lead to 1.8 seconds over Steckly; all the commotion with third as dropped them 10 seconds behind the leaders
2:11
Lap 20 - Ranger leads Steckly, Fitzpatrick, LP Dumoulin, Lapcevich, Labbe, Hathaway, Kennington, Micks, JF Dumoulin
2:13
Lap 21 - LP Dumoulin gets the position on Fitzpatrick to take p3 coming to the line; holds him off thru Turn 1
2:14
Lap 22 - Andrew Ranger has opened 3.9-second lead on Scott Steckly (2nd place)
2:15
Lap 22 - Physical battle between Arseneau, Dowler and Roy in Turn 1 has Roy emerging with p14 coming thru Turn 2
2:16
Lap 23 - Jason Hathaway,(Dodge/MOPAR) running p7, has been posted; Heavy smoke coming from the car.
2:17
Lap 23 - RSeibert closing on Guenettte
2:18
Lap 24 - Full course yellow as BWhite stalls at turn 1. Appears to be rear axle dragging. This changes everything!!!! Andrew Ranger looses a near 4 second lead due to the caution flag!
2:19
Lap 25 - Under yellow, Ranger leads Steckly, JP Dumoulin, Fitzpatrick, Lapcevich, Labbe, Kennington, JF Dumoulin, Micks, Guenette
2:20
Andrew Ranger's last lap was 1:38.834; Best lap was 1:37.960
2:22
Jason Hathaway (Dodge/MOPAR) still out on the track with his car still smoking. Will get black flag with white stripe to stop scoring next time by if he doesn't come in
2:22
Field just got 1 to go to green in Turn 12
2:23
Lap 25 - Ranger and Steckly leading field to green
2:24
Lap 26 - Ranger keeps lead, and Steckly, Fitzpatrick and Lapcevich fall into line. Everybody gets thru turn 1 and 2 ok
2:26
Lap 27 - Ranger leads Steckly by 1.138, then LP Dumoulin, Fitzpatrick, Lapcevich, Kennington, Labbe, Micks, JF Dumoulin and Roy
2:27
Lap 28 - Ranger started opening up the lead (2.157) as Steckly has hands full with LP Dumoulin
2:29
WHITE FLAG: Ranger leads by 3.461 over Steckly, LP Dumoulin and Fitzpatrick
2:30
Ranger appears on cruise control at this point; Could get interesting for p2
2:30
Andrew Ranger wins the Jiffy Lube 100 presented by Snap-On from start to finish from the pole!
2:31
Steckly holds on for P2 over LP Dumoulin; Fitzpatrick, Lapcevich round out top 10
2:31
Kennington finished p6, followed by Micks, JF Dumoulin, Roy, Guenette
2:32
Labbe finished p11, followed by RSeibert, Scannell, JWhite, Beauchamp, DWhite, Courtemanche, Dowler, Arseneau, Hathaway, DWhite, TSeibert, Jackson, Vanniini
