They might be good. There is a 5V regulator on the back of the instrument panel which, if it fails, causes the gauges to be inoperative. Unless you tested the gauges that you bought with a separate power supply on a bench to demonstrate that they're bad, I'll bet they work. If you tested them in the car, check the 5V regulator. It's probably bad.
