Anyone know how to get this cover off? I need to get the cover off the steering column/ignition lock mechanism so I can get to the linkage between the lock and the rod that goes to the ignition switch module down on the column.
I couldn't get my truck to start yesterday evening. I've been having to turn the key a lot farther than usual to engage the starter, and then last night I could tell that it wasn't moving the switch far enough. Turning the key all the way barely gets the ignition to come on, let alone engage the starter. The switch module works because I can move the connecting rod w/ pliers and start the engine. I think the linkage between the lock and the connecting rod is worn or come loose.
It has a tilt steering wheel.
