Here is an idea of what you want to purchase and what needs to be checked prior to purchase.
Pistons, as you mentioned, will need to have the block checked to determine whether or not she needs bored, thus oversized pistons. There are three basic levels of pistons, being cast aluminum, hypertuetic(might be spelled wrong), and forged. Cast for stock applications, hyper or forged, a little and much more expensive, but not jaw-dropping expensive, hyper gives a good balance of cost and durability to heat.
Rods, unless broken or bent, can be checked and resized to make sure they are straight and true, which is much cheaper than new ones, if you can actually find them new or aftermarket, new piston end bushings installed if needed (I believe they are).
Gasket set covers all the gaskets needed for the overhaul, and would cover everything except your 4bbl carb itself, it isn't offered for the slant six (ever), which is understandable.
Oil pump, you would want high volume if possible, and if not available, break a new one down and open up the flow passages, it improves flow and volume and isn't a real ton of work, always good practice to clean up the flow on a pump anyway.
Distributor. If you have points (because it hasn't been converted to electronic at this point), plenty of aftermarket companies out there to convert at a reasonable price, Pertronics has been pretty decent about making conversions, so make sure the bushings in the distributor housing are good and the shaft doesn't wobble.
Bearings. That's up to you, but rod and main bearings are relatively inexpensive actually, should get the tri-metal bearings for durability, also go by the name Clevite 77.
Pushrods. Check them, verify they are straight, tips aren't worn out, and no, they don't get ground, they simply get replaced if worn. Now rocker arms are a little bit different story, the end of the valves can indent or over time form a wear pattern. This can be gently sanded/ground out of them to fix that issue, and if not mistaken, the rockers are both adjustable and bronze bushed and can be replaced to improve stability and rocker arm geometry.
The camshaft itself, which is where the power of the 4barrel carb gets to do its work put to the test. It is a solid lift cam, with solid lifters and adjustable rockers, but you don't want to go too radical, which would be difficult to drive on the street. So, from the specs on your stock cam, which can be looked up or profile verified with a dial indicator and degree wheel (all cam grinding companies can verify what you have and what they can do), but basically, and increase in the duration of the camshaft by 12-15 degrees and an increase in lift of .050-.075 inch over stock would wake the engine up without killing its drivability. There are several aftermarket companies that make new cams with this type of profile, they used to call them RV cams (about a step above stock, maybe a hair more). Or you may have access to a cam grinding company that can help out on this one, including refacing the lifters.
Lastly, the head. Given porting is probably out, clean everything up, make sure things like rough castings in the ports are ground with a grinding stone, or my favorite tool is a carbide burr cutter, about the size of your index finger to the first knuckle. It has a rounded end and it good to keep corners from getting too tight. We can talk porting and touching up the combustion chamber later, this is getting pretty long, but will get you headed in the right direction to get things started.
And one other thing, the "rebuild kits" that are cheap, are just that, unless they give brand names, they are designed for quick flip out the door running to an unlucky buyer.
