TIRE CHAINS (TRACTION DEVICES)
Use of traction devices require sufficient tire-to-body clearance. Follow these recommendations to guard against damage.
• Traction device must be of proper size for the tire, as recommended by the traction device manufacturer.
• Use on Front
Tires Only
Due to limited clearance, the following traction devices are recommended:
4x2 Front-Wheel Drive (FWD) Models
• Original equipment 225/60R17 and 225/55R18 tire sizes are
not chainable.
• The use of 7mm snow chains is permitted with the use of 215/60R17
tires on size 17 x 7.0 ET41 wheels.
4x4 All Wheel Drive (AWD) Non-Trailhawk Models without a Two-Speed Power Takeoff Unit
• Original equipment 225/65R17 and 225/60R18 tire sizes are
not chainable.
• The use of 9mm snow chains is permitted with the use of 215/60R17 tires on size 17 x 7.0 ET41 wheels.
4x4 All Wheel Drive (AWD) Non-Trailhawk Models with a Two-Speed Power Takeoff Unit
• The use of 7mm snow chains is permitted with 225/65R17 and 225/60R18
tires.
4x4 Trailhawk Models
• The use of 9mm snow chains is permitted with the use of 225/65R17 tires on size 17 x 7.5 ET31 wheels
