Welcome to the forum. Given you don't have smog requirements to worry about, you will need the motor and transmission (slant six trans is different), motor mounts, which can be sourced from Schumacher, they have a kit for that, You will need to redo the exhaust, and redo some wiring. Now there is a little bit to do, if not mistaken, about the exhaust manifolds, I think the truck manifolds are different, dump in a different place to clear the frame rails, best to check into that. Otherwise, it is a popular swap and quite fun. Double check the rear end you have, make sure it is going to be able to handle the extra power and tire spinning.
