Where's the leak? And how bad? Is the case cracked? Otherwise the only places for potential leaks are the transmission lines, transmission cooler, around the pan and the selenoid gasket. Is the transmisison fine otherwise? Need more details. Is the transmission slipping? Any TCM fault codes?
I think you're stuck staying with the 4 speed auto (41TE). I know there was a 5 speed manual,but I believe it was only available with the 2.0L 4 cylinder engine. My son had a 98 Avenger with the 2.0L/5 speed manual.
Is the recommended replacement a MoPar Reman? They usually have a 3 year/100K mile warranty. If you do replace the transmission, I strongly recommend replacing the transmission cooler and associated lines. They can clog up with debris over time. Flushing doesn't always work.
