Indeed, for all its weightiness, the original Liberty was not very big inside or out. The current Cherokee is spacious inside in comparison.
More likely the next Cherokee starts with the 2.0L hurricane as the standard option. I don't know what the future holds in the 3.2L vs. a successor to fit in that slot. More likely they keep powertrain options separate between the two vehicles, which means the next Cherokee will not have the I6 as an upgrade option. That will belong to the next Grand Cherokee.If they are making RWD they have to stuff an I-6 in it.
A Cherokee Trackawk with an inline-6 sounds awfully appealing.More likely the next Cherokee starts with the 2.0L hurricane as the standard option. I don't know what the future holds in the 3.2L vs. some derivative of the next Grand Cherokee's I6. More likely they keep powertrain options separate between the two models, which means the next Cherokee will not have the I6 as an upgrade option.
This is FCA - you will be up-modeled, and you will like it!A Cherokee Trackawk with an inline-6 sounds awfully appealing.
Parked side by side, Liberty appears much larger (perhaps because of different shape, and it’s much taller?). I imagine the extra length for Cherokee is accounted for by its longer snout. Interior cargo room, there is no comparison...Liberty has an extra 4.4 cubic feet of cargo space behind the second row (29 vs 24.6) and an extra 14.1 cubic feet behind the first row (69 vs 54.9). I guess packaging is everything...and I suppose Cherokee probably has to account for more safety equipment which takes up room.Pretty sure it's already bigger than the Liberty.
Edit:
2002 Liberty - 71.6" wide, 174.7" long
2012 Liberty - 73.1" wide, 176.1" long
2019 Cherokee - 73.2" wide, 182" long
In fact, the Liberty is closer in size to the new Compass.
The interior specs are very similar, with Liberty better in some areas and Cherokee better in others. Where Liberty shined was it’s cargo capacity...something that’s lacking in the current Cherokee.Indeed, for all its weightiness, the original Liberty was not very big inside or out. The current Cherokee is spacious inside in comparison.
Question is on which platform will Cherokee end up. Small "ultra stretch", Compact, Giorgio, Giorgio G. I can see Compact EOL with this Cherokee.This is FCA - you will be up-modeled, and you will like it!
We know that the I-6 is roughly 3.0L in displacement, correct? Perhaps the I-6 will come in a number of different configurations based on the application. For example, in the Ram pickup (the heaviest application) it might use dual turbos or the twin-scroll turbo. For something smaller like the Cherokee, perhaps a single turbo would suffice.I thought I read the Cherokee will have the I6 as a differentiator between itself and the Compass. The Grand Cherokee will rely more on extra size and high end models to separate from the Cherokee. All subject to change of course.![]()
Guessing something between Giorgio and Giorgio G. Like I keep saying, Dodge was at one point supposed to get a smaller RWD crossover, so it can probably share build points with a theoretical RWD Cherokee.Question is on which platform will Cherokee end up. Small "ultra stretch", Compact, Giorgio, Giorgio G. I can see Compact EOL with this Cherokee.
As I said I can see the major difference between Giorgio and Giorgio G up front. Which engines can be fit. Giorgio has only 2.0, 2.2 diesel, and V6 90° which sits very low. We can only speculate what else fits and with which repercussions
Italians can give a hand with V6 90° for Trackhawk if it's necessity.
I think that Stelvio is just about right size for its class. More boxy Jeep design will just offer even more space.Guessing something between Giorgio and Giorgio G. Like I keep saying, Dodge was at one point supposed to get a smaller RWD crossover, so it can probably share build points with a theoretical RWD Cherokee.
GG seems like it's made for larger vehicles, right?
Additionally, perhaps the I-6 will vary in displacement a little depending on the application, such as 3.2L for the Ram and 2.8L for the Cherokee (I'm just making those up).
Don't forget the FCA patent from a few years ago that would allow for a lower valvetrain height (or something like that?) which might come in handy for an otherwise tall I-6.
So maybe I'm wrong on the details but right on the fact that the I-6 will use different forced induction strategies and other add ons (e-Torque, hybrid, etc) depending on the application?AFAIK you are thinking in the wrong direction. Search P2 mild hybrid, electric supercharger...
Actually it's important due to packaging.So maybe I'm wrong on the details but right on the fact that the I-6 will use different forced induction strategies and other add ons (e-Torque, hybrid, etc) depending on the application?
Don't be fooled, Liberty has more usable space. Better packaged.Pretty sure it's already bigger than the Liberty.
Edit:
I have owned both vehicles (well, 1st gen Liberty) and my impression from my memory of that vehicle was that the Cherokee at least simply "feels" bigger inside. I always found the Liberty's cargo area nice and tall - but very short front to back which limited the horizontal size of objects with the back seats up. I found the Cherokee's cargo area much more usable for what I typically carried.Don't be fooled, Liberty has more usable space. Better packaged.
I amazed myself that the two boxed items I bought last night fit in my XJ Cherokee.Don't be fooled, Liberty has more usable space. Better packaged.
Cherokee's length goes to the snout, and more leg room for the rear seatI have owned both vehicles (well, 1st gen Liberty) and my impression from my memory of that vehicle was that the Cherokee at least simply "feels" bigger inside. I always found the Liberty's cargo area nice and tall - but very short front to back which limited the horizontal size of objects with the back seats up. I found the Cherokee's cargo area much more usable for what I typically carried.
