1 - 20 of 23 Posts
04 QC Dakota 4x4 3.7l 5spd manual
A few days ago I noticed that my oil pressure gauge was reading low pressure. After replacing the sensor I'm getting the same reading.
Help.
Is that at idle with a hot engine? And what viscosity of oil are you running? What part of the world are you in (what daytime temp)?
Discussion Starter · #3 ·
At idle, but no fluctuation with rpm's. It's like that hot or cold, Missouri and 70-80 deg's
Night pic is hot motor, day pic is cold
It’s probably time to get the oil pressure tested. I’m assuming you’re not hearing any noises from the low pressure.
They make a test gauge that screws in place of the factory sending unit. If it’s really low, it’s either a bad oil pump or worn engine (excessive bearing clearances) causing the low reading most likely.
Measure the actual oil pressure with a mechanical gauge. Any engine noise? Any stored fault codes?
Rectangle Organism Font Parallel Circle
Font Parallel Rectangle Number Screenshot
Is the sensor 1-wire or 2-wire? If it's 1-wire, it has no dedicated ground wire, it relies on the threads in the block to make the ground. And if you use teflon tape, that insulates the ground and gives an incorrect reading.
Some sensors have a thread cut such that it's tapered and makes a tight oil seal without teflon tape, so that the ground connection there is tight.
Reactions: chuzz
What's the ODO reading?
Discussion Starter · #12 ·
it appears as 1 wire and I did use teflon tape
1 - 20 of 23 Posts
