Yes, because normal oil pressure will be between about 8 psi to 14 psi at idle, to about 55-70 psi at highway speed, depending on engine temp and RPMs.
5w30It doesent seem to be exeptionally low for a hot engine.
- what viscosity does the oil have? (10w-30 or...)
They said I now have 70psi at 3kDid they give you a hot idle pressure value? If the pressure is above 4 psi at hot idle, the instrument cluster is probably the only thing left to replace. If the cluster is a CCN module, it may not be plug n' play. A used or an exchange cluster would have to be configured to your VIN in order to play nice with the other modules.
The gauges are designed to have a wide middle range, so they really aren't accurate, just more assuring to the operator.
Incrementally, but yes, it sweeps.Does the oil pressure gauge do a full sweep with the cluster self-test?
Can I just run a mechanical and poopies can the sensor?Honestly, if it is the gauge/gauge cluster failing, rather than the cost and hassle of replacing, for accuracy and peace of mid, I would find a way to tee in an adapter where the oil pressure sensor is located and hookup a manual oil pressure gauge.
It does that.I suspect the gauge driver on the cluster circuit board is failing. There should be 4 pointer increments; low, normal low, normal high & high.
You're correct.I was thinking last night that since the cluster gauge driver can position the gauge pointer at the correct points during the self-test, that the cluster itself may be OK?
No Teflon, that blocks the unit being grounded.it appears as 1 wire and I did use teflon tape
That is indeed what it does. Each position that it stops at is a calibration point.I think that the self-test is also performing a gauge calibration?
That issue was immediately rectified.No Teflon, that blocks the unit being grounded.
