Your tech articles on the radios and such have been outstanding. Have you had a digital dash cluster that's used in the 87 through 89 LeBaron Premiums and some Daytons of the same vintage apart for evaluation ?
I have several malfunctioning clusters. One where the VFL display is totally dead, another where the T,V,O gauge readings (temp, voltage and oil pressure, all share the same single bar graph display)are very erratic and jump all over the place and yet another where parts of the VFL display illumination vary light and dark in horizontal bands across the main part of the display. Sort of like the display is driven from two voltage sources and the voltage is applied in alternate horizontal axis'across the width of the VFL tube.
In all 3 cases the problem is within the cluster as substitution with a completely functioning cluster works perfectly. I've had these apart and looked over the pcbs for cold solder joints, hairline cracks or overheated areas and didn't find any. I used a magnifying glass but maybe I should find one with more magnification.
Have you any experience with these ? The IC's are not well identified and I was thinking that I could take the three of these and make one good one if I could determine which chip held the mileage and then build out from there.
I've not been able to find a schematic, parts diagram or anything at all on these clusters. These appear to be Huntsville ( or at least USA ) produced.
Help!
Help!
