Welcome to Allpar. P0300 (multiple cyl misfire) can be commonly caused by plugs, wires and coil, but like any fault code should be diagnosed first before just replacing parts...twice.
It can be ignition, fuel or mechanical related. There was a spark plug change for some 2.4L engines:
http://oskin.ru/pub/chrysler-dodge/manuals/Temp/TSB-08-008-04.pdf
The correct Mopar/Champion Coppers or NGKs are recommended as other brands or types may cause problems.
P0440 and P0441 are evaporative emission faults that may be related to each other, but not to the misfire.
NVLD stands for Natural Vacuum Leak Detection. It took the place of the older LDP-Leak Detection Pump. Go by your underhood emission hose map to trace the evap vapor flow.
Review some possible causes and then use the process of elimination to get closer to the root cause. Shared causes between different problems are the most likely cause.
Find out what you can with the tools that you have. A good detailed (factory) service manual may be your next best investment.
P0300-MULTIPLE CYLINDER MISFIRE
When Monitored: Any time the engine is running, and the Target Learning Coefficient
has been successfully updated.
Set Condition: When more than a 1.8% misfire rate is measured during two trips. Above
3000 RPM 1 trip less than 3000 RPM 2 trip.
POSSIBLE CAUSES:
INTERMITTENT MISFIRE
VISUAL AND PHYSICAL INSPECTION
IGNITION WIRE
ASD RELAY OUPUT CIRCUIT (COIL)
ENGINE MECHANICAL PROBLEM
IGNITION COIL
COIL CONTROL CIRCUIT
SPARK PLUG
CHECKING FUEL PRESSURE
FUEL PUMP INLET STRAINER PLUGGED (LEAN)
RESTRICTED FUEL SUPPLY LINE (LEAN)
FUEL PUMP MODULE
CHECKING FUEL LEAK DOWN (CHECK VALVE)
FUEL INJECTOR OPERATION
ASD RELAY OUTPUT CIRCUIT (INJECTOR)
FUEL INJECTOR
INJECTOR CONTROL CIRCUIT
PCM (IGNITION SYSTEM)
PCM
P0440-GENERAL EVAP SYSTEM FAILURE
When Monitored: Engine Running. Fuel Level greater than 12%. Ambient Temperature
between 4°C and 32°C (39°F and 89°F)
Set Condition: The PCM does not see the NVLD swtich close during the medium/large
leak test. The PCM then will increase the vacuum supply to the EVAP system by
increasing flow through the EVAP Purge valve. If the switch does not close with an
increase in vacuum an error is detected. Two Trip Fault.
POSSIBLE CAUSES:
EVAP PURGE SOLENOID VACUUM SUPPLY INSPECTION
EVAP PURGE SOLENOID
NVLD SWITCH OPERATION
GROUND CIRCUIT OPEN
NVLD ASSEMBLY
NVLD SWITCH SIGNAL CIRCUIT OPEN
EVAPORATIVE EMISSION LEAK DETECTION
PCM
P0441-EVAP PURGE SYSTEM PERFORMANCE
When Monitored: Cold start test. Engine Running. Small Leak Test Passed.
Set Condition: The PCM activates the EVAP Purge solenoid gradually increases to
maximum flow. During flow, the PCM looks for the NVLD switch to close. If the PCM does
not see the NVLD switch close at maximum flow an error is detected. Two Trip Fault.
POSSIBLE CAUSES:
CHECKING EVAP PURGE SOLENOID FUNCTIONALITY
VERIFY NVLD OPERATION
TEST A
POSSIBLE CAUSE
