I am getting no power to the right fog light. It appears that this is controlled by the BCM, with power passing through the IPM under the hood. There doesn't appear to be a fuse for this, and the left and right fog lights are powered by different drivers. I have tried removing the IOD fuse and the BCM fuse (not at the same time) to see if resetting things would help. Of course, it didn't. The wiring looks intact, but it disappears into a bundle not far from the light.
Is this something a dealer or shop with the proper scan tool can fix, or should I just use the power from the left fog light to energize a relay and hook both lights through the relay?
