1 - 7 of 7 Posts
Can i take a 4.7 engine out of a 2003 Durango and put it in a 2003 pickup truck ?..will there be anything special i need to do to make it run or is it bolt in and go??
Discussion Starter #3
It was also a 4.7 but i was told it wont work because of the tone ring on the cam and one on the crank
If this is during the 2002.5-to-2003 changeover from the JTEC (Jeep-Truck Engine Controller) to NGC (Next Generation Controller), the swap will be more difficult and parts will have to be retrofitted to match what system the truck has. Avoid changing over the system if you can by finding the right engine.
The engine sales code for JTEC is NZC and the NGC sales code is NZD.
You need to determine which system your truck has first.
As long as your vehicle has an automatic transmission, the JTEC PCM should have 3 connectors and the NGC have 4 connectors?:
JTEC (SBEC):
NGC:
The sales codes should be found on an underhood tag or emissions label. It can also be looked up with the VIN.
Discussion Starter #7
Well that sounds like good news then because the Donor vehicle has 4 plugs on the pcm and an automatic trans and my truck has the very same thing! Sounds like i can move on with the swap
1 - 7 of 7 Posts
