Plymouth Savoy: 1951-1964, from high-end to entry-level
by Ben Deutschman of the NY/NJ Slant-Six Club of America (see Ben's 1960 Savoy) with additions by the Allpar staff (many based on Plymouth 1946-1959)
The Plymouth Savoy debuts in 1951 as a Plymouth Concord model
The 1951 Plymouth Savoy was just a sub-model of the
Concord - a premium station wagon. It debuted in the same year that Plymouth assigned distinct car names to every trim level (Concord, Cambridge, Cranbrook, and Suburban), replacing alphanumeric codes and Deluxe / Special Deluxe trim. All Plymouths were still the same car with different trim, sharing a single engine.
The car had a conventional design, with a welded steel body on an arc-welded frame with double-channel box-section side rails and five crossmembers (the convertible had an X-member frame). The floor pan was channeled and ribbed, and there were box-section reinforcements around window and door openings. A baked enamel finish completed the package, with the final car tipping the scales at around 3,184 pounds.
Like GM and Ford, Plymouth used springs up front and leaf-springs in back; steering used a worm and ball bearing roller gear, with symmetric idler arm linkage, rubber-isolated pivots, and ball-joint steering knuckles.
The Savoy's engine was the Powermaster-6, largely unchanged from 1950. Savoy buyers gained chrome trim around the windshield and on the window divider strip, with more brightwork on the beltline areas, sides, rear fender stone shields
(stainless steel), and tailgate hinges; and full wheel covers with whitewall tires. Due to Korean War time
restrictions, which hit chrome especially hard, not all options were available at times.
The cost of the 1951 Concord Savoy - which used the Suburban body and seating layout - was a hefty $2,182.
The Plymouth Savoy gets nameplates
The 1952 Savoy officially became a separate model, though it was still a dressed up Suburban wagon. Plymouth cars claimed some 46 improvements, which included a redesigned engine combustion chamber; improved launching due to changes in the transmission; better brakes, shocks, wipers, and washers; and an overdrive gear, added in spring 1952.
1954 Plymouth Savoy
Weight: around 3,000 lbs (1360 kg)
Engine: 230 cid / 3.8 liter, 2 valves/cyl.
Horsepower: 110 hp (81 kW) @ 3,600
Torque: 190 lb-ft (258 Nm) @ 1,600
3.25 x 4.63 bore x stroke, c/r 7¼:1
3-speed manual, 3.90:1 final drive
193.5 long x 73.5 wide x 61.7 high
Production figures for the Savoy were lumped in with the overall Suburban wagons; 76,520 of these were made. The 1952 Savoy
listed for $2,287, and weighed in at 3,165 pounds.
The 1953 Savoy moved into the higher class
Cranbrook series in 1953, as the Concord had been dropped; it now used Belvedere interior styling, with better materials for the
upholstery and trim. Brightwork was similar to the Cranbrook. A two-tone option gave the buyer a white roof
and solid lower body coloring. The fuel filler cap was moved from the rear to the left rear quarter panel. The base model sold for $2,187, and weighed 3,170
pounds.
Plymouth also added "Tip-Toe shifting," what many have come to know as Plymouth's Fluid Drive Transmission (not a full automatic).
There were 12,089 wagon models produced by Plymouth for 1953 across all models, with no breakout for the Savoy.
The Savoy breaks out of the wagon
Chart courtesy of the Plymouth Bulletin
The 1954 Savoy was shuffled around again and given a $5 price cut, as the Cambridge and Cranbrook were renamed. The Savoy was now just above the base model (the Plaza), and was now sold in sedan form ("Club Sedan") and as a coupe - the base Savoy Club Coupe sold for $1,835, and
weighed 2,986 pounds. Options included a two -tone paint scheme, with the roof being the lighter color; a
fully automatic transmission (the 2-speed Powerflite); power steering; and in March of 1954, power brakes.
The Club Sedan production total for 1954 was 25,396 units, and the Club Coupe drew 30,700 sales. Overall, though, 1954 was not a good year for Chrysler Corp, nor the Plymouth Division, which suffered nearly a 40% drop in sales.
The 1955 Chryslers were dramatically different in styling; the Forward Look styling, created by Virgil Exner, put Plymouth back in fourth place for 1955. The Savoy coupe was dropped, but the Club Sedan was joined by a four-door sedan; the Club Sedan accounted for 74,880 units sold, and the four-door Sedan accounted for 162,741
units sold.
The brakes were good, the front drums increased to 11 inches, the rears remaining at ten. Power brakes were an option, as are air conditioning, power windows and power seats, but all were rare on Plymouths.
Somewhat controversial was the new dashboard, which put two gauges in front of the passenger for symmetry; the shifter was built right into the dashboard. Dashboard-mounted shifters would be a minivan standard in the 21st century, but not behind the steering wheel. It was a one-year placement.
Another new option in the 1955 Savoy line-up was the V-8 engine, in 157, 167, and
177 horsepower versions; it joined the flathead six.
The 1956 Savoy now had a base 180 horsepower, 270 cubic inch engine for V8 buyers, as well as a 12-volt electrical system, pushbutton-controlled automatic transmission, and auto record player (which took special records to avoid skipping). The six continued.
The 1956 Savoy lineup was the Sport Club Coupe, the Club Sedan, and the four-door Sedan. The Sport Club Coupe was a Hardtop, in base model trim, selling for $2,233, weighing 3,275 pounds, and sold in both the six and V-8 versions, with 16,473 units sold. The Club Sedan listed for $2,086 in base trim, and sold 57,927 units for that year.
The six cylinder
Savoys had a horizontal bar through the rear trunk medallion, and the V-8
models had a V emblem on the Hood, and a V through the Trunk Medallion. Once again though, the four-door
outsold all other Savoy models, bringing in 151,762 orders for the 1956 model year. The price for the
base model Savoy four-door was $2,129, and it weighed 3,295 pounds.
The 1956 Savoy also gained a dashboard redesign, keeping the same appearance but moving the gauges back in front of the driver, replaced by heater controls, with two gauges replaced by warning lights to fit within the design. The car made it harder for lone drivers to adjust the heat.
A major restyling took place across the Chrysler product line-up for 1957, and a brand new front
torsion-bar suspension system was employed. So successful was this new front
suspension system that it remained the mainstay of Chrysler front suspension design, until well into the
1970s.
The 1957 Savoy and its companions jettisoned the outmoded styling that had characterized Plymouth since 1950, and shot forward three years - "Suddenly, it's 1960," claimed the ads, and for good reason. GM's famed styling boss, Harley Earl, was called onto the carpet when the Plymouth catalogue arrived at General Motors' headquarters. Ford was caught equally off guard.
Unfortunately, the cars were rushed into production, and while they sold extremely well, they also made many enemies and permanently destroyed Chrysler's reputation for quality and reliability. Rust was everywhere, parts broke off, and customers were lost. Chrysler would have been much better off in the long run had the 1957s bombed in the marketplace - or, more to the point, if they had done a late launch, but fixed the problems before release.
The 1957 cars were also the first with the TorqueFlite automatic transmission, which opened up Plymouth to many new buyers who rejected both manual transmissions and the two-speed PowerFlite. The TorqueFlite dominated automatic transmissions for the next two decades, and was sold to American Motors and to high-line European makes; technology was reportedly licensed to Ford. The TorqueFlite earned a reputation for durability and efficiency which remains to this day, allowing automatic-equipped drag racers to win against manual-transmission cars.
Other new items for 1957 included a
longer wheelbase for the Suburban wagons, four inches longer than for the other cars. The Savoy was sold with the Flathead six or a 301 cubic inch V-8,
with two barrel (215 hp) or four barrel (235 hp) versions.
The 1957 Savoy was still a step up from the Plaza. Club
Sedan production for 1957, was 55,590, the cost in base trim was $2,364, and the coupe weighed 3,335
pounds. The two-door hardtop sold 31,373 units, cost 2,329, and weighed 3,335 pounds. The four-door Hardtop
Savoy accounted for only 7,601 units porduced, sold for $2,417 in base model trim, and weighed in at 3,480
pounds. The production leader for the 1957 model year in the Savoy model, was the four-door Sedan, which sold
55, 590 units, sold for 2,364, and weighed 3,340 pounds. The V -8 models carried a V emblem
on both front fenders, just ahead of the wheels.
For 1958, there were few apparent changes, and they were largely to address problems. Quality was dramatically improved, as it had been through the 1957 model year. The lower bumper pan was replaced by a lower grille matching the upper section, and real dual headlamps were built in, with the parking lamps moving to a small spot above the twin headlamps.
While 1958 wasn't a banner year again for car manufacturers, Plymouth did manage to hang on to its
third place sales position in the industry. The Savoy was back again, offering a two-door Sedan, a two-door Hardtop, a 4-
dr Sedan, and a four-door Hardtop. Engine choices were the carry over Flathead six, and the 318 V -8. The two-door
Sedan sold 17, 624 units, was priced at $2,362 without any options, and weighed in at 3,360 pounds. There
were 19,500 two-door Hardtop Savoys built, which listed at $2,436 with the V -8, no figures available for six
cylinder versions, if any were produced. The four-door Sedan Savoy accounted for 67, 933 units produced, was
priced at $2,413 with the V-8, and weighed in at 3,400 pounds. The four-door Hardtop version of the Savoy, sold
only 5,060 units, was priced at 2,507, and weighed in at 3,475 pounds.
The 1959 Savoy was suddenly the base Plymouth; there was no more Plaza. V-8 engines included the 318 again, in two and four barrel versions, along with a Golden
Commando V-8, referred to as the Golden Commando 395 (it had 395 foot pounds of
torque). Transmissions were a three-speed manual, two-speed automatic, and three-speed automatic. Options included swivel front seats, a headlight dimmer, and a self dimming
rearview mirror.
Savoy offerings included the two-door Business Coupe, accounting for only 1,051 units
produced, selling for $2,143 and weighing in at 3,130 pounds, the Savoy two-door Sedan, which sold 46,979 units,
at a base price for the V-8 version of $2,352, and weighing 3,425 pounds , and yet again the top seller, the
Savoy four-door Sedan, which had a production total of 84,274 units, and with a V8, was priced at
$2,402 list in base model trim, weighing 3,390 pounds with the V8. Basic options were power steering, power brakes, and automatic transmissions.
Brand new for 1960 was the Slant-Six straight six cylinder engine; with engines taken from the divisions and made into "corporate" designs, Plymouth buyers could now buy a 361 and 383 cubic inch V8 in addition to their earlier options (the Standard Catalog of Chrysler makes no mention of these options, but factory brochures list them; the 1961 brochure claims they are both "available on all models" of Plymouth, save for Valiant).
The 1960 Savoy's main technological feat was conversion to a unitized
body (six cylinder cars with automatic transmissions had an aluminum
case as well). 1960 was also the last year for Chrysler to use generators; the Valiant had a standard alternator and all other Mopars would, too.
The Savoy came basically in two forms for 1960, the 2-door, and 4-door
sedans. There were 26,820 two-door Savoys built, selling for $2,379 with a V-8, and weighing in at 3,490 pounds (in base V8 trim). The four-door Savoy came in with a total of 51,384 units built, sold
for a list of $2,429 in base trim, with a V-8, and weighed 3,500 pounds. Ben Deutschman's 1960 Plymouth
four-door Savoy, with a slant six and Torqueflite automatic, listed for $2,675; his father had paid $2,100 for the
car on June 13, 1960.
The 1961 Savoy would still only be a sedan; it was positioned above the commercial Fleet Series. Under 19,000 two-doors sold, with under 45,000 four-doors. The four door weighed 3,465 pounds; pricing started at $2,381 with a V8 two-door. The PowerFlite was now history, with only the
Torqueflite carrying on. (The following chart is from Plymouth.)
The 1962 Savoy added a wagon to the lineup; 12,710 wagons were sold with a starting price of $2,717, and 3,390 pounds of heft. 18,825 two-doors and 49,777 four-doors were sold in 1962, with engines carried over. Four door production rose somewhat, while wagons and two-doors remained fairly constant. Options included power steering and brakes, and the rare air conditioning, which may not actually have been installed in any Savoy.
The 1963 Plymouth Savoy looked more conventional, and was three inches longer and one inch wider than the 1962; it came with turn signals, electric wipers, dual sun visors, front armrests, and little else. The Savoy came as a two or four door sedan, and as a four-door station wagons with two or three rows of seats. Fewer than 20,000 1963 Savoy wagons were made, versus nearly 80,000 sedans. The 145-horse slant six continued; the base V8 was still the two-barrel 318.
The 1964 Plymouth Savoy was the last, but Plymouth tried to boost sales with a new front, rear, and instrument panel; under the hood, buyers could get the new, "lightweight A" 273 V8 and a four-speed floor-shift manual transmission. The two door, with a higher production of 21,326 units, started at $2,332 with V8, at 3,205 lb; the four-door sold 51,024 units, starting at $2,388 and 3,210 pounds; and the six and nine passenger wagons sold 12,401 and 3,242 units respectively, with the six passenger starting at $2,728 and the nine-passenger at $2,829. The nine passenger wagon was a hefty 3,600 pounds. It ended up being a good year for Savoy sales.
The Plymouth Savoy enjoyed a 13 year model run, and ended on a high note. Like many Chrysler Corporation vehicles, its positioning was not always consistent; and it was dropped while still moderately popular. By 1964, though, the Valiant was far and away Plymouth's big seller.
Thanks to Don Butler's Plymouth-Desoto Story | See Ben's 1960 Savoy | 1951-1959 Plymouth Savoy details
Home •
Engines •
Reviews •
Chrysler 1904-2018 •
Upcoming •
Trucks •
1954 Plymouth Savoy
pounds.
units sold.
The six cylinder
1970s.
rearview mirror.
Home •
Engines •
Reviews •
Upcoming •
Trucks •
