One of the guys on the Woodward forums shop got a HELLCAT towed into the shop already. The supercharger pulley, backed off and onto a radiator hose. First known issue for the HELLCAT, but again the HELLCAT is being tested.
Photos by Kyle Malone.
Is anyone making a "mountain" out of it? I don't think so. It's just an interesting thing.Mike V. said:It's a preproduction car, they are out being evaluated so problems like this can be addressed before they make it to the general public.
Mountain out of a molehill.
Mike
A Poly V belt is actually fairly normal for this application. Other OEMs use similar setups.Jerry Simcik said:Is anyone else surprised they're not using a cogged belt? (Think timing belt.)
aftermarket upgrade potential......Mike V. said:A Poly V belt is actually fairly normal for this application. Other OEMs use similar setups.
Gilmer belts (cogged) are normally used on high torque aftermarket rootes blower applications.
Mike
To add...Jerry Simcik said:Is anyone else surprised they're not using a cogged belt? (Think timing belt.)
IMHO, no, not really or necessarily.Moparian said:aftermarket upgrade potential......
Yeah, not really a big deal.redriderbob said:It's exactly what I heard, was just in there for the night for storage. Not every department at CTC is open 24 hours.
Why? I've never seen a toothed "timing belt" ever used on a factory supercharged vehicle before. They're mostly used by hotrodders supercharging their old-school V8, probably because they look cooler than a multi-rib belt.Moparian said:aftermarket upgrade potential......
On a related topic...Those kind of problems most be seen and fixed bythe CTC, no other option, so don't believe another story.
If its a vendor, supplier etc. evrything UNDER the CTC roof, and thats it.
No further comments. !!
Yes, Poly V is the common belt for the application.Why? I've never seen a toothed "timing belt" ever used on a factory supercharged vehicle before. They're mostly used by hotrodders supercharging their old-school V8, probably because they look cooler than a multi-rib belt.
There's very few automotive supercharger applications that truly need a cogged belt, and most of those are probably the 2000HP+ dragsters, simply because the belt-tension needed to stop a reasonably-sized multi-rib belt from slipping would snap the drive snout right off the blower.
Even motor-alternator start/stop systems use standard multi-rib belts. They just have a special electronic tensioner that rapidly increases the tension for starting, then backs off.
I have an 09 CTS-V, but I don't yet have a lot of info to provide. There has been a lot of talk about it, but information on what GM is actually doing is still sketchy. (They may be in the process of snail-mailing owners.) It's not clear to me whether this is a recall or if they're just extending the warranties to say they'll fix it if and when needed; I suspect the latter. Some reports say it's only 2011 and newer cars that are affected. The issue as I understand it is that the bearing shaft grease gets contaminated and eventually the shaft fails, leading to a loud screeching and then kaboom. Best case is that the supercharger is toast; worst case is that the engine inhales some bits and is also toast. Either way, you'll be driving the loaner for a while.Mike V. said:Do we have any GM guys here that can provide additional info?
I believe GM uses a different supplier than Chrysler does for their supercharger.georgejetson said:I have an 09 CTS-V, but I don't yet have a lot of info to provide. There has been a lot of talk about it, but information on what GM is actually doing is still sketchy. (They may be in the process of snail-mailing owners.) It's not clear to me whether this is a recall or if they're just extending the warranties to say they'll fix it if and when needed; I suspect the latter. Some reports say it's only 2011 and newer cars that are affected. The issue as I understand it is that the bearing shaft grease gets contaminated and eventually the shaft fails, leading to a loud screeching and then kaboom. Best case is that the supercharger is toast; worst case is that the engine inhales some bits and is also toast. Either way, you'll be driving the loaner for a while.
FWIW I haven't had any of the ominous rattling that supposedly precedes a failure, so I'm not too worried yet. I'll wait to see what shows up in the mail over the next week or two.
Correct re suppliers. The GM superchargers are made by Eaton.Mike V. said:I believe GM uses a different supplier than Chrysler does for their supercharger.
I do know that the GM warranty replacement takes roughly three hours.
Mike
Sorry, I was going by my cousin's time. He is a GM tech.georgejetson said:Correct re suppliers. The GM superchargers are made by Eaton.
I have heard that replacing the supercharger is more like a 6 to 7 hour job (per the book, at a dealer). Of course if it's two techs, that's a three hour job. Either way, I'll wait and see what GM says.
Muther said:So wait, the sky isn't falling?
