I just rebuilt the 2.7 in my03 Sebring with a five speed. It turns over fine but does not fire. I've tried every sensor and wire with no luck, all test ok. I have spark as tested with a plug out and grounded. I have fuel, I've been trying everything under the sun, and because the injectors are firing but not running, the gas has seeped past the rings so the oil smells like gas.
I think my timing is out.
Questions:
Can the flywheel be attached in more than one location? I rotated it on the crank until I had the holes lined up. I assumed It can oly go on one way.
Also, concerning the timing chain. I read that the timing marks on the chain will move in respect to the marks on the sprockets when the engine is rotated. So, installing the chain and rotating a coup,e times to check the marks doesn't help, because the chain marks will be off. Is this correct?
Questions:
