So, i replaced the main and rod bearings on a 2.7 V6 out of a 06 charger after it spun the no. 2 and 3 rod bearings. I was able to replace the bearings without pulling the timing or dropping the crank...
My question to yall being; is there any special procedure to priming the engine with oil other than cranking it over by hand and am i required to use 5w-20 or is 5w-30 acceptable?
