Hi,
I just joined Allpar.com. I bought a LeBaron Convertible, 1990, V6, 3L in September 2012. Been in a garage over the winter and will be a kind of "summer car").
When i bought the car one of the "quarter windows" was not possible to get down. Easy to fix this spring/summer i planned...
The other one also stopped (both stopped in "upper position").
I wonder if someone have som ideas around this kind of "window problem"?
Is this something that happend for other owners? Cable and connection problem somewhere? Engine potentially dead? other ideas? Can i check if i have power from battery to the panel ("up and down" stearing of each window) at the left door? Multimeter? how to connect "at the socket/pins"?
I guess that i need to remove the backseat and panels on each side to be able to check the window engines and connection/cables, or?
I cannot find instructions how to do remove the seat etc, so very helpful if someone got som short guide/ideas also here.
Thanks in advance!
Regards Jan
Thanks in advance!
Regards Jan
