Welcome to the forum.
Have you checked the springs in the secondaries? It is very common for them to be too soft and allow them to open too quickly, causing a bog. There is one in the front and one in the rear, Holley makes a spring kit with color coding and they can be changed to adjust the speed of which they open. Start with the heavy and medium spring, one in front, other in the rear, then go to the medium spring changed to the medium light, then the medium replacing the heavy.....you get the idea. Get the secondaries to open before the bog, the bog is opening too soon, vacuum will force the seconaries open so go to the bog, then back the spring set back one stiffer to stop it. Works every time.
